Grit on Dishes, tripping breaker
I’ve had a problem with gritty dishes for some time now. Thanks to this forum I learned how to get to the chopper / macerator and check it for debris. I cleared out a lot of bone chips etc and the dw worked better, but still left grit. Yesterday a new problem arose; the dw will start, fill with water, but will then trip the breaker. We pulled the unit out and found a mouse house, but none of the wires were chewed.
I’ll be grateful for any trouble-shooting help.
Remove the bottom panel, open the junction box and check all wires.
Remove the door panel and the control panel and check all wires.
Check the control board for any burned spots.
Post your findings, please.
Here are the break down diagrams for the Kitchen Aid dishwasher Model KUDS01IJWH0
Dear Gene -
Thanks for the help - I’ll proceed as you suggest and will report back.
Best wishes,
Skip
Hi Gene -
As you suggested, I inspected the wires and control panel and everything checks out. I also re-checked the macerator/chopper and that’s fine.
I did find something out of order, which I can’t fix - the internal rear feed cap is stuck on the lower wash arm assembly and won’t unscrew. Could that be the problem? How do I separate the two parts?
Skip
Hi Skip,
Can you provide the drawing reference number(s) for the part you are talking about?
Also the cause of the problem (tripping the breaker) could be a bad breaker itself. Plug the dishwasher in a different outlet and see if it’ll work.
Here’s the link to the parts diagram
Model KUDS01IJWH0
The dishwasher is hard-wired so I can’t switch outlets.
I need the reference number for the "the internal rear feed cap ".
If the dishwasher is hard-wired, I would recommend to call a certified electrician to check the circuit breaker for the dishwasher. It’s very good chance the problem is there.
This part
AP3039146
is stuck in this part
AP3039143
In order to release the spray arm this part has to be turned CCW while you holding the spray arm with a second hand.
The lower spray arm hub has become cross threaded and so won’t unscrew from the wash arm assembly. I’ve no idea how it became cross threaded and can not for the life of me separate the two parts. Any tricks of the trade?
Well, just break it off and replace with a new part. I do not see what else could be done?
Hello Again Gene -
The replacement parts (for the jammed spray arm hub and wash arm assembly) came today and I installed them. Sadly the dishwasher still trips the breaker - it will run through a complete cycle of “Rinse Only” but trips early in any of the wash cycles - soon after the unit is filled with water. Does this info give you any clue as to what might be wrong?
Looks like there is a problem in the heating circuit.
You have to check the heating element, the hi limit thermostat and the corresponding wires for a short to ground.
Thanks Gene - will do
