I have grease and oil under my washing machine. The oil is leaking from the transmission, but I also have black grease on the top of the transmission shaft (by the sproket) and also down below on the motor, etc. Is this grease also coming from the transmission or is there grease leaking out of the drive tube? Just not sure what part has all this grease in it to replace.
The only oil or grease in this model is in the transmission, so either the stuff is coming from something you washed or it is from the transmission. Replace the transmission or fix the leak and clean everything up and see if that does not fix the problem.
