Grease marks on my clothes
I noticed that our clothes have been coming out from the washer with little grease spots.
Can I fix this problem?
If you can assist I would greatly appreciate the help.
[quote=liketofix;689459]I noticed that our clothes have been coming out from the washer with little grease spots.
Thanks[/quote]
You might have an issue with the tub seal or possibly some built up grime below the agitator.
There are probably videos on how to remove the agitator on this site or Youtube. Remove it and see if there is a lot of built up grime or dirt below agitator… if not, then you might have an issue with a seal.
If you think it is built up debris, run an empty load with hot water and distilled white vinegar or a washer cleaner. They might sell some cleaner on this site.
Just a thought…
