None of my burners on my oven will heat up. The oven is still working properly, but the burners went out suddenly this evening. Is there something I can do to fix this without replacing the range?
Replacement parts for JB700CDCC models | AppliancePartsPros.com
Getting tech info on GE’s is near impossible they like to keep it a secret, probably keeps their tech’s busy.
Open it up nad check at the terminal block and inside the control panel, sounds like a wire that is common to all your burner controls may have burned off or has a bad connection.
Also check that there is not an overheat thermostat or a thermal fuse in the common wire.
