Glass Surface Triple Element replacement
I have a Maytag Gemini range, Model #MER6875BAS purchased in July of 2007. I’ve seen other posts on Gemini’s with links to Service Manual PDFs but never this exact model.:frowning:
The front right burner is a triple element burner. The center (smallest) element has quit operating. The middle ring and outer ring elements work fine.
I was hoping that they were 3 separate elements that could be replaced individually but from what I’ve seen here I now expect that it is a single assembly containing all three elements.:frowning:
I would like specific instructions for removing the top, and replacing the triple element assembly.
What testing can I do to confirm it is the burner and not the switch at fault.:confused:
Thank you for any assistance you may provide.:slight_smile:
The problem can be a bad heating element as well as the switch for this burner. Both parts have to be checked for continuity.
Here is the Service manual.
Here are the breakdown diagrams and Replacement parts for MAYTAG MER6875BAS Freestanding - Double Oven - Electric | AppliancePartsPros.com
Please Tell Me Which Wire Goes Where Color Wise Connecting Triple Element Part 74011844 To Maytag Mer6875bas
Please Advise Wire Sequence Connecting Triple Element To Maytag Mer6875bas
How the old element was connected?
The tech sheet is attached to the reply.
Here are the breakdown diagrams and Replacement parts for MAYTAG MER6875BAS FREESTANDING-DOUBLE OVEN-ELECTRIC | AppliancePartsPros.com
MER6875BAS.pdf (577.7 KB)
