I have a Gladiator garage freezerator. Top section is refrigerator lower secion Freezer. A month ago I started finding small ice deposits on the top shelf of the freezer. It is now getting worse, more and more water leaking from the opening in between the secions, square hole top center of loer compartment by vent. lots of water now forming to ice.
Thanks in advance for the help.
Thomas
[quote=Shmota;222781]I have a Gladiator garage freezerator. Top section is refrigerator lower secion Freezer. A month ago I started finding small ice deposits on the top shelf of the freezer. It is now getting worse, more and more water leaking from the opening in between the secions, square hole top center of loer compartment by vent. lots of water now forming to ice.
Thomas[/quote]
Shmota, I am having exactly the same leak with my Gladiator, did you ever get an answer? – gary
Yes, I did. If you are still having problems let me know and I will leave a link to help.
Please do, still have the problem and would love to have your link for help. thanks, – gary
I am also having this problem. Can someone post the solution? Thanks.
Eric
I have a Whirlpool Gladiator Freezerator that is building ice on the bottom part. Need to knife it out about every other month. What is the solution? Very frustrating. I don’t understand how this can happen. Thanks for any help
Greetings, all!
I’m having the exact same problem. Can someone toss me the solution?
Thanks a ton!
I am also having the same problem. Could someone send me the solution also? Thank you!
Can you please let me know the solution. I have had 2 service call by authorized repair companies and my refrigerator is still leading into the freezer. Thank you.
[quote=Smith1234h;504079]Greetings, all!
Thanks a ton![/quote]
I’m having the same problem and can’t find the solution. Can someone help?
Thanks!
Can you please send me the solution to the leaking water into the freezer?
Thank you
I see that other have had the same problem. What was the solution???
Thanks,
Darryl
Yes. The drain has ice in it. At the back of the fridge section there is a center bump and two downward sloping “ramps” on each side of the center bump. Either defrost completely, or pour hot water on the “ramps.” I took mine completely apart and changed the defrost Tstat, which is what I think causes the problem in the first place.
Later, and stay safe.
Bill
Could you post the link you used to repair?
[QUOTE=deepwilliams;760559]I’m having the same problem and can’t find the solution. Can someone help?
Thanks![/QUOTE]
I am having the same problem. Can some help?
freezer iceing to lower freezer
[QUOTE=Shmota;255073]Yes, I did. If you are still having problems let me know and I will leave a link to help.[/QUOTE]
I am having this problem - lots of ice in the bottom of the freezer part. What is the solution and can you help - Thanks KJF17
I’m having the same problem as well…can someone please post the solution? Is there a link?
