Ginger0616
Dryer starts and last about 2min. then stops?
Replacement parts for MAYTAG MDE9206AYW DRYER- ELE | AppliancePartsPros.com
When it stops can you restart it right away or do you have to wait a couple minutes?
If you have to wait the most likely cause is an overheating motor.
It overheats and it’s internal thermal protect trips so you have to wait for the motor to cool down and the protect to reset before you can re-start.
Common causes are:
Too much load caused by the drum.
A bad internal seal and hot air is being blown onto the motor.
The motor has lots of lint on it so it is not cooling properly
The motor is on it’s last legs.
