Gibson gas dryer not starting
I have a Gibson heavy duty dryer (DE/DG27A5-A) which has been in storage for 5 years. It worked when it was stored. I plugged it in today and when I pushed the start button, it would not turn on. I pushed it for 2+ seconds as stated in the manual. I was wondering if there is a fuse/circuit breaker on the unit that may have flipped. I checked the outlet and it is good. It is a gas dryer (not currently connected). Can you give me an idea as to what the problem could be?
Put the dryer in the trash. No need to comment on this post.:frowning: [quote=tad.marinelli;797655]I have a Gibson heavy duty dryer (DE/DG27A5-A) which has been in storage for 5 years. It worked when it was stored. I plugged it in today and when I pushed the start button, it would not turn on. I pushed it for 2+ seconds as stated in the manual. I was wondering if there is a fuse/circuit breaker on the unit that may have flipped. I checked the outlet and it is good. It is a gas dryer (not currently connected). Can you give me an idea as to what the problem could be?[/quote]
