GFD49ERSK0WW front panel removal
Brand: GE
Model Number: GFD49ERSK0WW
Main Symptom: general disassembly
This dryer is especially tricky to disassemble if you don’t know this little trick. The front control panel is easy to pry upwards with a putty knife. There are two clips holding the control panel down into the face of the main body on either side. Try between the silver lining of the control panel and the white metal of the front of the body.
This gives you access to be able to remove the top.
Thank you for sharing what you found. It is very true that there are tricks that can be used to help make a disassembly or repair process easier to accomplish.
