Gets hot before start, then wont start
Electric dryer, less then 2 years old. Maytag But really a Whirlpool.
When you turn timer the heat coils come on immediately, if you turn it to a setting that would require heat. That is BEFORE you push the start button.
If you set it to another setting, like tumble only, there is no heat.
The start button does nothing in any case, the motor does not come on.
I thought the timer was bad and took to the parts store and explained my problem and was told the motor was probably stuck in the on position and would need a new motor. Got new motor and same problem, arrrggg.
Was I right that it was the timer?
Cannot say you have to do more troubleshooting.
You may have 2 problems.
I cannot find a wiring diagram for this unit so am doing a bit of guessing.
First I would check the heater to see if it is grounded.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on whenever the door is closed.
This condition may have blown a thermal fuse (Item 7 in Section 3).
With the unit unplugged remove both wires from the fuse and check it with the meter, should be 0 ohms. This fuse kills power to the motor.
The most common cause of this fuse blowing is a dirty/clogged vent system so check/clean it.
Problem solved. I took off the heating coils to see if there was a problem there and bingo. It seems that the coil was touching the metal on the dryer. Just straighted out the coils a little bit and reinstalled. Oh and a new thermal fuse and she is as good as new.
