This Machine Quit, Clean Light Flashes7 Times Short Delay And Flashes Again. The Machine Never Heated The Water Or Dryed The Load. I Will Check The Heater Circuit. But How Do You Re-set The Control Module?
[quote=G HALLAHAN;753158]This Machine Quit, Clean Light Flashes7 Times Short Delay And Flashes Again. The Machine Never Heated The Water Or Dryed The Load. I Will Check The Heater Circuit. But How Do You Re-set The Control Module?[/quote] THIS IS THE MESSAGE
While the dishwasher is in standby, press High temp scrub (Power scrub) - Air dry (No heat dry) - High temp scrub - Air dry
or
Sani Rinse - Air dry - Sani rinse - Air dry.
