Have GE Profile dishwasher and bottom of dishwasher retains water up to 1" deep. In looking at the exploded view, which shows the pump and the bottom spray arm, it appears the water coming into the washer is from below thru the pump moter assembly. I believe the water is exiting the rear (bottom) of the machine and no pressure operated drain is indicated on the schematic. When I cleaned out the standing water I cdid find some lint like material but it did not appear enough to block water from the rear drain. Please advise hopefully before I pull out the machine and make an a-- of myself (even more).
Many thanks,
Terry Peters
mizippipete@megagate.com
phone: 601-261-2508
