Spins Slowly On Spin Cycle
Take off the front cover and see if you can read an error code, which is generated by a blinking green light. Here is how to interpret the codes
HydroWave GE Washer Repair Guide
Before doing anything try resetting it using the instructions in the link. A lot of times that will fix things.
