My washing machine fully drains but the pump does’t shut off and allow the spin cycle to begin. I get error code E31 could the water level sensor be causing this? About amonth ago the machine overfilled once. Is there anyway to test this. I checked the door sensor and it is good.
GE does not release tech data so we cannot interpret this error code or tell you how to check it.
I suggest you contact GE and see if they can get you some tech info. There may also be a tech sheet inside the machine, so check there.
