Ge Washer
:confused:Washer will fill and spin but will not agitate.
We need the model number of the washer.
Eric
Wwsr3090t6ww
Take the front panel off the machine by inserting a putty knife into the top groove in line with the lid opening on each side to release the clips, tilt panel outward and lift from machine. Does the motor run when it should be agitating? Does it hum? Is it totally quiet?
Eric
Motor does run when it should be agitating.
And belt and main drive pulley are turning?
Still trying to get front cover off - being stubborn and I am not a fixer.
Small tubing connected to drum on left but not on right seems to be disconnect not sure if one piece or broke.
Found problem 3 parts holding the drum have broken. TY
Ty found problem
