washer does not fill when i push start ,worked the day before,but now it`s a sequence of lights and nothing else,?
GE does not make it tech data available, but look inside the console and see if there are tech notes that will help you diagnose what is wrong.
Unplug the washer for 30 seconds, plug back in and see if it fixed your problem..,.
