Hello, my washer will rinse, aggetate and sometimes spin but not all the time. I checked the belt and it’s tight and the gear seems to move fine. Sometimes the cycle will keep going right through the other cylcle’s without stopping. It’s alive!!! Could it be the switch and if so how do i get at it? Help!!:eek:
Since the timer does not stop I suggest you try changing out the timer, this part here.
You can get to it by removing the screws in the top of the console.
If it does not fix the machine and you order from this site you may be able to return it. See the returns policy.
