Ge washer wont wash
Brand:GE
Model Number: GUD27GSSMWW
Main Symptom: washer wont finish cycle
What happens & when: When starting normal washing cycle machine , the machine will fill the just turn off. all lights turn off. There is not a digital display on this machine , so it doesnt display error codes. Technician held start button in for a few seconds and told me it should reset it. Now telling me it needs mother board.? If dial is turned to drain and spin it will work.
I’d recommend testing the machine in the service mode, I’ve attached the service manual below.
The washer’s field service mode starts on page 63.
31-9292.pdf (2.3 MB)
This is what I came up with.
Test1
press start and wash and spin flashing
press start and on, wash ,rinse flashing
press start and on, spin, lid lock flashing
press start and spin and lock flashing
press start and on, wash, spin flashing
press start and on, wash, lid lock flashing
press start and rinse , lid lock flashing
press start and lid lock flashing
press start and wash, rinse, lid lock flashing
test 2
lid lock flashing
Test 3
1st press of start Lid lock
2nd Rinse and spin flashing
3rd All off
4th spin flashing
Test 4
1st press of start lid locked
2nd rinse and spin flashing
3rd all off
4th all off
Test 5
2nd rinse ,spin flashing, lid lock on solid
3rd all off
4all off
Test 6
1st press of start Lid locked
2nd lid locked
3rd all off
4th all off
Test 7
2nd lid locked
3rd all off
4th all off
Test 8,9,10,11, 12 all seemed to work normally
Test 13 No spin
Test 14 No Agitation
Did # 15 with no change in performance
So those codes look to be:
9 Lid Switch Redundancy
28 Options Knobs Feedback Invalid
19 UI State Timeout
3 Locked Rotor Monitor
26 Out of Balance (OOB) Ended Final Spin
25 Pressure Sensor Dropout
5 Mode Shifter
1 Lock Monitor
13 Redundant Lid Unlocked
Going through them there’s a lot of variance in what they mean. The main control may be at fault, but we’d be unable to confirm that without testing each component referenced by the given codes.
