GE Washer won't spin dry clothes
My washing machine will fill, agitate, drain, refill and drain again but will not spin dry during the rinse and spin cycle. What can I do to fix this? I took apart the timer to make sure that it was working properly. I can’t diagnose but can usually fix things when I know what the problem is. HELP !!!
Take the front panel off the machine. What is it doing when in spin mode? Motor running? Just humming? All quiet? If running, is belt turning? Or clip on bottom of motor shaft spinning but pulley not rotating?
Eric
When the spin cycle starts, the tub fills with water and drains. It makes a humming kind of noise and the motor never moves. It also constantly makes a sucking type noise. But everything else is ok. It fills, drains, and agitates.
Is it the drive motor that is humming? Are you saying that when you manually place timer in spin that it fills with water???
Eric
After the wash cycle, there is a rinse/spin cycle. The tub fills up and rinses the clothes and drains. Then it does not spin at all. I dont know what is humming. I do know that it constantly makes a sucking sound.
Does it spin during the wash cycle?
yes, it agitates during the wash cycle
Agitate and spin are two different things. The washer should fill, agitate, drain, spin (wash cycle), fill, agitate, drain, spin (rinse cycle). Does the basket with the clothes in it ever spin?
it doesnt spin
Ok, when washer has drained and should start spinning, turn washer off. Unplug one of the wire terminals from the pump so it won’t make any noise. Turn washer back on. What does the drive motor do? Do you see the clip on the bottom of the shaft below the pulley spinning? If not, is the motor humming at this point?
I am at work at the present time. I will try that when I get home. What else can I try? What am I looking for? What would your diagnosis be?
I can’t make a diagnosis at this point. The only thing I know is that your washer won’t spin.
Eric
So if i unplug the pump and the motor still doesn’t spin, what could it be? What if the motor is humming? What if the motor is not humming? What if the little pin is turning? What is the little pin is not turning? The motor? The clutch? The coupling? The belt?
washer has a 2 speed clutchless motor and it is not spinning on spin cycle.i can manually spin the tub to get it going and it picks up speed and finishes the spin cycle. i have replaced belt because i could smell it ,i thought.used to spin ok with a light load but has slowly gotten worse
OKay…i ran the rinse and spin cycle…stopped the washer and unplugged one of the leads to the water draining pump. There was no noise. The motor wasnt humming, it wasnt spinning, the little pin wasnt spinning either. Where the pump was plugged in, it sounded like it wasn’t gonna stop sucking water out. It never stopped sucking until i unplugged it.
The pump runs continuously during the spin cycle so that it continues to pump water being spun out of the wet clothes. If only the pump runs during the spin cycle and the cycle ends and washer starts filling again and you never hear any noise from the drive motor during this time, the timer is bad. If you buy the timer from APP and it doesn’t fix the problem, you may return it.
GE WH12X10202 Timer - AppliancePartsPros.com
Eric
Just to make sure…when i unplugged the drain pump, all i heard was the timer ticking. The motor was not making any sound at all and nothing was spinning. So the TIMER will cause the washer not to spin? I took the front off the timer and made sure it was set in the little notch. So I need to purchase a timer?
Yes, that is most likely the problem. I say that because I am not there to troubleshoot your washer. If I was, I could say with 100% certainty whether it’s the timer or not.
Eric
I am having similar problems with my GE washing machine. I can’t get mine to rinse either. My washing machine spins the agitator during the rinse cycle, but the tub does not spin. But it spins fine during the washing cycle. I checked the belt and it does work during the rinse cycle. Do you think I have a faulty timer as well?
My GE Washer Model No. WHDSR316G3WW has the same problem.
Washer does agitate and water pump also works, but wouldn’t spin dry.
Been trying to look for the timer for my model but couldn’t find one. Does my model have timer as well, if so what is the part #?
Thank you very much in advance for the help.
Thanks.
