At first my GE washer would allow the water level to get to high and water would overflow and now it doesn’t want to spin and it also wants to run a second rinse even when it is not selected. When it runs a second rinse no water enters the tub but it agitates. Please help.
Thanks, John
[COLOR=#000000][FONT=Times New Roman][SIZE=3]Remove the front off the washer and look at the left hand side of the tub. You should see a tube connected to the tub, remove it and check to see if it is partially or fully clogged. If so clean it out and your problem will be repaired. If it is not clogged I would say the water level control is bad. Hope this helps! [/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3] Clothes Washer Repair Guide[/SIZE][/FONT]
[/COLOR]
