GE washer stops mid cycle
This washer stops after wash, then does nothing, i have cancelled cycle then put on spin and it works fine, i Ohmed out mode shifter and got 65 ohms. I reset by doing the lid lift. Also have never gotten any error codes on motor led. Bad board? Or any other way to check anything else? Any help much appelreciated!
It doesn’t sound like a mechanical problem, and with no error codes I can only suggest you change out this control board
AP4980168
If you buy from this site and that board does not fix the problem you can return it.
Good luck, let us know how it turns out. These models are the dickens to diagnose and every bit of knowledge helps.
