ge washer stays in drain w/ imin showing & Code E31 & start/pause blinks sometimes
Ge Adora fl washer keeps draining with one minute showing & the start/pause blinking somtimes also has shown an E31 fault code. The filter & pump have been cleared and two control boards installed…Any suggestions of whats wrong??
They have filled this machine with so much electronics I doubt if even the GE people can repair it.
Try checking all of the wiring between the pump and board and if that does not fix things try replacing the pump.
Here is a service manual from another site if you do not have one.
http://appliancejunk.com/ge/washer/31-9135.pdf
:confused: Well thanks for the info unfort we also have tried that as of this morning and still no change. If you should come across any other info it would be great!
If I get one in the shop I will take a look, but this model is difficult to work on and GE keeps their technical info like a state secret.
