Update - In the event there are other morons trying to fix their dishwasher…
Make sure the part you ordered is the correct part number. Kind of crazy that it almost worked…
Brand:GE Dish Washer
Model Number:GDF570SSJSS
Main Symptom:Won’t start
What happens & when: I push start, won’t start
Error Code (if any):None
Parts or tests already tried: replaced control board and UI board
Washer had no display, replaced the ui control board it and the display works now.
- Diag mode all 5 tests pass. I can hear water entering, drain pump running, and circulation pump, even the soap drawer opens.
- Leave diag mode and start button will give a two tone beep, but won’t start
- Door switch is good, diag won’t run with door open
