Ge washer not working correctly after replacing main control board
Brand: GE
Model Number: GTW460ASJ6WW
Main Symptom: lights flash sporadically, some cycles unavailable, not filling with enough water
What happens & when: installed new control board and programmed it but when starting a load the lights randomally flash then it goes to fill and has been working fine. It recently started beeping when not in use and randomly disperses water from time to time. I unplugged machine and waited then plugged it back in. Same thing. I put it on test mode using the owner manual of machine and went through the codes but not quite sure how to read them. I exited out and now there are 3 cycles that will not work, the lights do not come on for them and when pressing start button it just makes a error sound. I tried using the normal cycle but it’s not putting enough water into the machine to wash the clothes.
Parts or tests already tried:I replaced control board but before I did I also replaced the transmission and lid lock mechanism.
It would be recommended to make sure that you used the correct programming by getting the tech sheet to go into service diagnostics and check it.
