GE washer not filling
Brand: GE
Model Number: GFWH1200H0WW
Main Symptom: not filling with ater
What happens & when: water only runs for about 5 seconds
Parts or tests already tried: water inlet valve replaced and drain pump filter clean d
When the washer is started, do the valves hum when it should be filling with water?
