GE washer makes a noise
My washer makes a noise when it spins it’s not off balance or over stuffed. It drains fine and agitate fine it just makes a loud noise at the beginning of the spin cycle and gets quieter through the spin cycle but you can still hear it. Appreciate any help.
Problems like this are very difficult for us to diagnose because the main way we do so is to listen to the location and type of noise.
I can only recommend that you run the machine with the front off and try to determine if the noise is coming from the basket area or the transmission. There may be something between the tub and basket.
To take off the front insert a screw driver or putty knife in the gap between the top and front near the edges to release clips that hold the front on.
Good luck.
