Brand: GE
**Model Number:**GFW655SPV0DS
Main Symptom: Will not go into spin cycle
What happens & when: starts to spin and then aborts
Error Code (if any):E38
Parts or tests already tried: tested where the black hose goes into the board and got inconsistent values so I replaced the board, but that didn’t solve the problem. Disconnected drain pump, cleaned filter, ran pump and observed strong water flow and pump sounds good. I heard there is another screen or filter somewhere that needs to be cleaned due to well water mineral buildup but I’m not sure where that would be.
