I have a GE Under Counter Ice Machine that stopped making ice and the clean light came on. I ran two cleaning cycles and turned it back on and now the water fills the bin and water keeps circulating over the freeze plate but no ice is forming.
You need to determine whether the compressor is running or not. You should be able to remove the front cover that is in front of your condenser coils. Once it is removed, you can feel the copper tubing. if it is cold, more than likely the compressor is not running, and it may need a new start relay. If it is warm, you may need to get a certified tech out to check the sealed system.
