GE TrueTemp oven will not light. Broiler works fine in either hi or low mode. Oven glow bar never glows. I checked the voltage at the bake relay as shown on the schematic that came with the oven. It measures 1125VAC from the terminals BA to N when the oven is switched ON, and measures notheing when the oven is switched OFF. Any help would be appreciated.
Should have said that it measures 115VAC at the relay.
