I put my dogs bed in the washer this morning per the instructions and it was destroyed and now my machine will not drain. I emptied as much water as possible by hand and took the front panel off. With the panel off i see stuffing in the tub but don’t know how to get to it also I am assuming the drian tube b4 the motor is clogged. any help would be nice . thanks
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Usually all you have to do is take the pump hose loose and clean out the hose. Sometimes you have to take the drain hose off and clean it out as well. Hope this helps! [/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000][/COLOR][/SIZE][/FONT]
Clothes Washer Repair Guide
