GE Super Capacity Plus washer
Help. My washing machine was working fine on Saturday. On sunday however, it would only light up and not do anything else…fill, spin, drain. What gives? Any suggestions woul d help before I call GE Service Center. Yes, of course the waranty ran out the beginning of the month.
Try to unplug the washer for a few minutes. Some time it helps to eliminate a problem.
[quote=Gene;469893]Try to unplug the washer for a few minutes. Some time it helps to eliminate a problem.
Gene.[/quote]
Thanks Gene so much for your response. I have tried that and it still doesn’t do anything? I read online that it could be the lid switch or some type of valve. Do you think either one of these things are the problem. Help. I don’t want to call repairman if it is something simple. Thanks again.
:slight_smile:
