GE Stove
GE gas oven range. The right side 2 burners work manually. The left works when iginated- , the oven/broiler which at present does work. When trying to light oven. The ignitor glows but it take 5 to 10 mins. for gas to ignite. thank you. please advice:confused:
[RIGHT][/RIGHT]
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/1332-help-instructions-install-oven-igniter.html#ixzz26wh2LagC
Hi.
To fix the oven just replace the igniter
AP2020569
When you turn the right side burners on do you hear clicks?
When you turn on the left side burners does the right side sparks?
Post the results.
Simon.
