Brand:GE Model Number:JGB700SEJ4SS Main Symptom: Convect fan issues What happens & when: Convect fan starts , runs for 4 seconds, stops, then repeats. Replaced the control board and the temp sensor, what’s next?
Also getting 34.0 Ohms on fan motor with no power to unit
Parts or tests already tried: Control Board, Temperature sensor (WB20K10027)
4 seconds on, then off…over and over and over? I’ve cooked with other convection ovens, often they run for 20 seconds plus, then off, then on again for a different time.
With an ohm at 34, could the motor be bad…or at least going (bad)?
You may be on to something with that resistance reading, had to do some digging to find a model that used the same convection fan AP6327842 and actually gave a resistance value. Looks like it should be around 411Ω, though it doesn’t specify which winding that should be on.
Just to follow up, the fan spins freely and the motor seems to turn on (and shut off quickly)…is there any other thing that could be causing the fan to turn on for 4 seconds and then turn off (and repeat)…?
