I just replaced my Oven Control Board, but to my suprise I don’t have the manual for stove to do the reset steps. Could someone please direct me to a manual or give me step by step to my stove work. (it would make my wife very happy. ![]()
Not sure what you are asking, You should not have to program this board. What is the problem you are having with the oven?
The main issue is the when you plug power back into the stove the display is flashing fast. If you try and set the time it still flashes. I read that I my need to do a programming reset after start up. IE hold down a the Oven and Broil buttons for three secons and then temp up button. Something along those line. I was able to get it cleared one time but when I tried to pre heat the oven the silinod was just clicking on and off, and no heat was coming on.
