Ge stove top double burner, large side not working
I’m Starting A New Post Because Of The Wrong Model Number I Used Previously. When I Use This Model # To Find Parts At This Website, It Brings Up The Correct Parts Pages. In Your Last Post You Said Since I Changed The Switch And That Didn’t Fix It Then The Element Needs To Be Changed.
Just To Repeat My Problem, I Have A Ge Stovetop That Has A Glass Top. There Is One Burner That Has A Small And Large Element . The Small Works Fine But I Get Nothing From The Large One. I Changed The Switch For This Burner But Still Nothing.
Do You Still Think It Is The Element That Needs Replacing?
Yes, I do. Especially if there is nothing wrong with the wires. I’m glad you were able to find the correct model number.
Here are the breakdown diagrams and Replacement parts for General Electric JBP80BH1BB Electric range | AppliancePartsPros.com
