Greetings I broke by front door glass on my stove door, shattered everywhere.. I called GE and they sent me the correct door for my model number..
JGSP23WEY8WW
Below is a picture, while this is not the exact picture for that part I believe it is close.. HOW to I do this, do I take the door off it’s hinges, lay it down on a soft surface, take the top and bottom screws out.
Seperate the from the back, clean out any old glass, intall new glass
Is there any extra trick involved?
[FONT=Times New Roman][SIZE=3][COLOR=#0000ff]https://genet.geappliances.com/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00015700/00015760.p03.pdf[/COLOR][/SIZE][/FONT]
[quote=samiam87;283964]Greetings I broke by front door glass on my stove door, shattered everywhere.. I called GE and they sent me the correct door for my model number..
[FONT=Times New Roman][SIZE=3][COLOR=#000000]JGSP23WEY8WW[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Below is a picture, while this is not the exact picture for that part I believe it is close.. HOW to I do this, do I take the door off it’s hinges, lay it down on a soft surface, take the top and bottom screws out. [/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Seperate the from the back, clean out any old glass, intall new glass[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Is there any extra trick involved? [/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Thanks[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#0000ff][URL=“https://genet.geappliances.com/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00015700/00015760.p03.pdf”]https://genet.geappliances.com/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00015700/00015760.p03.pdf[/COLOR][/SIZE][/FONT][/URL][/quote]
You’re on the right track to repair / replace your glass door.
There aren’t any secrets or special needs to replace it,
You should be able to do the repair using the parts diagram you have.
Good Luck,
