GE Stove control panel dead
My stove’s burners, including igniters work fine, but the control panel is dark and unresponsive, so oven can’t be turned on. Problem is probably due to too high a voltage (220) across plug due to a generator problem.
Trying to figure out what to replace. The control board and display panel seem not to be getting power (Vdd to ground is zero), so I assume problem is a power supply, but can’t locate it. Should I see a voltage (5-12 volts) across these wires with the unit plugged in? Is there a schematic likely to be hidden somewhere, and if so, where? Thanks for any help.
Hey there, did you find out what happened to your stove? I’m facing the exact same problem (model number JGB600SETSS).
