Hello,
My stackable washer/dryer only spins slow. It do not kick into final fast spin. I have replaced timer,motor&pump. I belive the trans is good beacause it dose spin and only the motor is 2 speed. This only leaves the clutch I think. If that is the case, what is the symptoms of a bad clutch? Or what could my promblem be?
thanks so much !!
[quote=realistic;203765]Hello,
thanks so much !![/quote]
Realistic,
You’re getting there, a slipping clutch or a dragging brake pad, could cause a slow spin,
AP2046416
AP6024664
as well as a bent, weak drive coupling, but that usually makes some sort of noise eventually.
The drive system on your washer is very similar to a different manufacturer’s so this should help you out,
http://forum.appliancepartspros.com/washer-repair/3265-replacing-direct-drive-washer-brake-shoes.html
Good Luck,
