How do I replace the dryer door switch?
Hi.
Please provide the complete model number of the unit.
Simon.
[quote=Simon / APP Team;781288]Hi.
Simon.[/quote] WSM2420 is the number I copied. Serial# isSH6006222. Hope this helps. Thanks.
There is more to the model number There are several models which begin WSM2420. Here is one example:
WSM2420D0CC
Other models have four or more letters and / or numbers following.
Double check the model number on the serial number plate.
[quote=TommyK;782949]There is more to the model number There are several models which begin WSM2420. Here is one example:
WSM2420D0CC
Double check the model number on the serial number plate.[/quote]
The unit is in Florida and I am in Ohio. I will be down thre next month and will get back to you then. Thanks very much.
The Model # is WSM2-42OD 1WW.
Hope this helps.
Hi.
You should be able to get to the door switch from the top by removing the top cover.
Here are the breakdown diagrams and Dryer Cabinet & Motor parts for GE WSM2420D1WW - AppliancePartsPros.com
The door switch AP2042951
Post the results.
Simon.
