GE Spacemaker XL1400 Stove top lights
Hello,
The stove top lights do not come on. I replaced the bults and they still do not come on. THe indicator on the front says toggles thru and says off, bright, and night. (mAybe not in that order or wording) Anyway the light does not come on. Any ideas?
Thanks,
Greg
:confused:
Help Please!!!
My KitchenAid hood combo has the same problem plus inside light won’t come on either… I’m thinking there may be a fuse that’s blown though… still waiting for some help in the forum before taking on any repairs.
Hi Greg,
Sorry for the delay.
The stove top lights operates by the control board. If there is no power to the lights then the control board has to be replaced.
Here are the breakdown diagrams and Replacement parts for GE JVM1440WA01 | AppliancePartsPros.com
Your question answered here: http://forum.appliancepartspros.com/microwave-repair/41627-kitchenaid-microwave-hood-combo.html
[QUOTE=Gbear;101835]Hello,
Thanks,
Greg
:confused:[/QUOTE]
Did you ever get a response to this? I have the same problem,
[QUOTE=jmich8;379807]Did you ever get a response to this? I have the same problem,[/QUOTE]
What is the complete model number of the microwave?
I picked up a Kenmore 363.62709200 microwave at a yard sale (for cheap, thankfully) and installed it over my range. The microwave part works great, but the first time I turned the light on, there was an almighty ZAP. I immediately shut the light off, disconnected it from power, and pulled both bulbs, which seemed to be in pretty rough shape. Fearing the worst, I plugged one bulb in and plugged the unit back to wall power. The microwave still works fine, but neither the light nor the range fan will turn on – the controls happily cycle through ā€œHI / LO / OFF,ā€ but there’s no response from light or fan. Oh, and I can hear a faint ā€œclickā€ as I cycle through the settings.
Any notion of how I’d go about diagnosing what part’s necessary? Is there a separate fuse for the lights/fan?
Thanks!
Adam,
Check all light sockets and wires from the control panel to the bottom of the microwave and replace the control board.
