I need to replace the stirrer motor in this over the range model. Any advice or tips?
Stirrer motor
Hi Guest,
Are you also trying to change a stir motor on a GE microwave?
A copy:
Answer: Typically the stirrer motor is located on top of the microwave. It moves the microwaves around inside the cavity. You need to remove the wrapper or cover to access it. It’s normally not a difficult repair. Thanks!
The stir motor is #60 in the parts breakdown.
LINK> GE WB26X10037 Stirrer Motor, Square Shaped Shaft. (AP2024961) - AppliancePartsPros.com
I also for this helps.
LINK> How to Troubleshoot & Replace: GE AP2024961 / WB26X10037 Stirrer Motor, Square Shaped Shaft.
I hope something here helps.
jeff sr.
Hi Guest,
A copy:
jeff sr.
Hi Guest,
A copy:
I also found this here.
jeff sr.
Hi Guest,
You are also changing a stir motor in an GE OTR microwave?
jeff sr.
