Ge spacemaker turns fan on when door opens
Hello,
I have what looks like a common problem. My ge spacemaker also turns the fan on when I open the door. I also have a problem with the turntable not working. Could you please let me know the part number for the door issue, and I will tackle the turntable later if I can. Other than that, micro works great. Hopefully I can repair door issue myself!
Thank You
Tim
Hi.
Most likely the problem is a bad door sensing switch
AP2024337
located at the top of the door switch bracket.
Regarding the turn table you should check the coupling
AP3416049
Here are the breakdown diagrams and Microwave parts for GE JVM1650WB008 - AppliancePartsPros.com
Post the results.
Simon.
