I installed a brand new Spacemaker today above my stove. I mounted it and every, I go to plug it in and turn it on to check it out and it is sparking inside the unit by the power cord. it is also making a poping sound. Any ideas?
I guess i should have checked it before i installed it over the stove. seeing that is it is brand new i thought it would work right out of the box.
There is something wrong with the power outlet or inside the microwave. Plug it in a different outlet, using an extension cord. If this problem still exist then call GE for the warranty service. If it would work, then you need an electrician.
Get rid of your GE Microwave
GE Microwaves can spontaneously turn on and start a fire - see Consumer Reports web page here or copy link below Kitchen Fire Safety - Consumer Reports
