I have looked at the posts. Mine is a little different.
My crisper is turning into a freezer which also causes the water line to freeze. Top of the fridge is warmer than the bottom. On the freezer side the bottom is cold but the ice maker is hot, there is water in the unit but it will not freeze. Help:confused:
Turn the ice maker off or unplug its wire harness and watch the refrigerator for a few hours. Put more attention on the cold air flow through the damper control (#426 on the diagram). Post the results.
[quote=Charles Neighbors;156789]I have looked at the posts. Mine is a little different.
My crisper is turning into a freezer which also causes the water line to freeze. Top of the fridge is warmer than the bottom. On the freezer side the bottom is cold but the ice maker is hot, there is water in the unit but it will not freeze. Help:confused:[/quote]
I am having pretty much the same issue as Charles. My bins in the fridge side are freezing, and the freezer is not freezing on the top part. I took the plate out in the back of the freezer and saw the coils are frozen over in the middle third, but not so much frozen over in the top and bottom thirds. I have a GE side by side, model GSS25TSRE. Any tips would be appreciated, and I will unplus the icemaker assembly like you suggest and look at the damper control.
You refrigerator has a different design compared to the one owned by Charles. The problem you described has nothing to do with the ice maker because yours is not hot. Watch the damper control and post the results.
After doing some searching it appears it may be the thermistor or the thermostat. Is there a way to check the thermistors, or should I replace them since they are relatively cheap anyway (compared to a service call)?
I checked the Fridge several times this weekend, with the ice maker off.
When the Fridge door is closed (holding the button) the Damper stays open all the time. When the fridge is open it closes. When I left the damper unpluged the water despenser works after is thaws out. Tried plugging in the damper and turning on the power to the ice maker, still no ice and the water line froze back up.
The fan is located in the freezer, behind the rear panel (#610 on the diagram). This is the only fan inside the refrigerator and freezer. Can you see that fan working when you open the freezer door?
There is the meat pan control (#442 on the diagram) on the bottom left side in the refrigerator. Make sure it is completely closed and check if there is any cold air coming through the damper on the upper left side.
Remove the rear panel in the freezer and check how the evaporator coils are covered with snow.
I looked at the damper assembly, but did not take it apart or anything. I noticed cold air coming out of the bottom of it, but without much force. I did not notice any differences when holding the button to simulate the door being closed. I can hear the fan working, but have not looked at it when I had that panel off in the freezer. As I said before, when I had that panel off, I noticed the coils were heavily frozen over in the middle third, but the top and bottom thirds were only slightly frozen over. I also noticed the ice maker, while it makes ice, sometimes gets warm because the ice becomes wet, and sometimes there are drips of water coming down from it. In the fridge, the drawers freeze anything in them, and I put a cup of water in there and it froze solid. The water line also freezes up, allowing no water from the freezer door to come out.
Is there a specific test I can do to check the damper out? I am not sure what I am looking for there, exactly.
Thanks for all your help, by the way!!! This forum is very much appreciated by me, and I’m sure others that find themselves in similar situations.
[quote=jaxcarlson;159477]There is only a humidity control for the drawers. I’m not sure what the meat pan control is.
Is there something I can check to make sure the damper assembly is the issue?[/quote]
Sorry, there is no meat pan control in your refrigerator. I mixed up your replies with replies posted by Charles. That’s why we do not recommend to use someones threads.
You can remove the damper assembly and check the gate inside. Broken gate is very common issue.
This is rather difficult to remove. I have the light assembly down, and removed the cover to the filter area, but am not sure how to remove the damper assembly. I feel like I am going to snap something off and not be able to put it all back correctly.
Okay, I got it removed, but wasn’t sure how to check that black gate. I ended up just sticking a long screwdriver in there and pushing it open. I had more resistance than I would guess something like that should have (I would think it would open freely with ease) and when I pushed it open it stayed there. This is symptomatic of a bad gate? Should I go ahead and order that damper assembly?
