Hello,
I need to replace the plastic water line/tube that runs up the freezer door up to the water/ice dispenser - because it is cut at the bottom corner of the freezer door.
Anyone have a diagram and/or advice on how to remove/replace it?
Thanks!
I am having the same problem, I need to replace the water line going into the freezer door. I was wondering if you ever found a way to replace the water line. Thanks
[FONT=Times New Roman][SIZE=3][COLOR=#000000][/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]I am having the same problem with aGE model number GSS25WGPDWW.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000][/COLOR][/SIZE][/FONT][FONT=Times New Roman][SIZE=3][COLOR=#000000]I have replaced the valve solenoid.I have left the freezer off with the door opened for over three hours. I evenconnected a bicycle pump to the tube where it enters the freezer door, andpumped it up to 50psi. I have checked three different fix it yourself websites. No one has been able to explain how to replace the tube inside a GEfreezer door.[/COLOR][/SIZE][/FONT]
