[SIZE=3][FONT=Comic Sans MS]my frige is warm and the freezer is the temp that the frige should. it has decreased temp over the last few days, also the it is not producing ice. is this because it needs to be recharged with coolant? if not, what else should I check?:eek:[/FONT][/SIZE]
If all the fans are running and condenser in the back clean, you have refrigeration problems for a pro to look at.
