Only two burners lighting (right rear and left front). The left rear and right front do not spark. I thought maybe it was the spark module, but ruled it out by removing the burner head and just placing the burner cap closer to the electrode, doing this made the electrode spark. Could the burner cap be so worn out that over time the gap between it and the electrode is to big for the spark to jump? This stove has sealed burners. Any help is appreciated!!
Hi Juan,
The problem can be a bad igniter (damaged ceramic) or a bad spark module.
Remove the burner cap and the burner head. Remove the two screws secured the burner base and lift up the burner base. Inspect the igniters.
If there is nothing wrong, replace the spark module which is inside the control panel/
Here are the breakdown diagrams and Parts for GE JGB920TEC2WW Range - AppliancePartsPros.com
