Ge refrigerator
The freezer of my GE refrigerator is working great but the refrigerator part is not cooling at all..I have had to throw everything away! Could this be the temp control?
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it’s open.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. How to test-Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Part 648 on diagram 4 is your timer. Replacement parts for GE GTS18DCMCLWW | AppliancePartsPros.com
where would the flap controller be? I did find the two holes in the back of the frig from the freezer…i dont hear anything running? i turned the freezer down to #4 and the frig to #5
