Brand:GE Model Number:GSS20IBMBWW Main Symptom:no power to the condenser What happens & when:Plug in power cord, condenser fan runs, but the coils/ freezer doesn’t get cold.
Parts or tests already tried: Replaced condenser, condenser start relay, condenser fan motor.
Tested connector for power where it plugs into the start relay. No power.
Resistance of Compressor good.
Is the evaporator fan running?
If the compressor, condenser fan and evaporator fan are all running with no cooling, you likely have a sealed system issue, which will need an EPA-Certified technician to complete the repairs.
It should be warm and feel a small vibration when running. If the fans and compressor are running and it is not cooling, you will need an EPA-Certified technician to complete the repairs.
