GE refrigerator is stuck on crushed ice
Ice maker will despence crushed ice ..but will not do cubed ice…burning smell..also noticed part of augor blade broke
nothing is moving at all .it is stuck in crushed ice position ..there are so many parts to go with this ..not sure what it needs..
Unless you can see a loose wire connection on the solenoid and there is no noise coming from it when you try the dispenser, I would start with the solenoid.
I had this same problem but without the smell.
-remove the ice bucket
-in the rear on the left side you wil see a square hole where the metal rod from the ice bucket rests
-you should be able to freely move the actuator up and down, if not use a little up and down pressure until it frees up
Done, now it dispenses cubed ice!
[QUOTE=SDTim;653533]I had this same problem but without the smell.
Done, now it dispenses cubed ice![/QUOTE]
Thanks, worked for me also!
Carefully use a heat gun under the solenoid/auger motor panel to thaw out an ice build up.
